Unconfigures all SSM mappings on the virtual router.
| vr-name | Specifies a virtual router name. If the VR name is omitted, the switch uses the VR specified by the current CLI VR context. |
N/A.
None.
The following command deletes all IGMP-SSM mappings on the virtual router "xyz":
unconfigure igmp ssm-map vr xyz
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IPv4 multicast feature, see the Switch Engine v33.1.1 Licensing Guide document.
